front stabilizer rod?
macattack
on my mack 688s mr i have a rod that goes between the front springs on the rear hangers. it is held by a nut on each end. what i noticed was it looks like its also welded on the inside. is this correct? looks to me the weld let go on each side. could i remove and just reweld the rod?
you can see the weld spots on the rod. dont know if i should reweld it or replace.
thanks
post-5017-0-82072500-1319932704_thumb.jp
post-5017-0-04611600-1319932861_thumb.jp
