Ideal Mack Medium Duty -
Im looking at trucks now to pull a 3 wedge style hauler. Many use Ford or Dodges with the Cummins or Powerstroke. However, my thinking is a used medium duty truck would be much more up to the task.
Can anyone reccomend a later model Mack model & engine combo ? Fuel economy/reliability will be big factors.
Brad
Cuba, Mo
1960 Mack B61
1985 Mack R686
1970 IH Loadstar 1600
If your looking for something like the DT powered IHC's or FL Freightliners, Mack doesn't offer one. When I worked for the local Mack dealer, one of our customers was a drainage tile company (plastic drain pipe, no weight-lots of bulk) who needed a medium duty truck. The one owner did all the spec work for them, spec'd super light weight R690's with EM-7's and 7 speeds, had a special order code for a super low profile, light GVW suspension/platform. Needed to lower the truck, in order to get as tall a rack as possible on the unit to put as much tile on as possible. It would have been easier for the customer to order a Lopro IHC 4900, but they like their Macks. Recently seen some low-pro Granites with their name on the door.
There is always a used Midliner or Freedom, but then your not getting a Mack.
T.
