#3 Injector Sensor Light Comes On
The light comes on every now and then, is the injector sensor serviceable? is the injector 3 maybe clogged?
Thank you for any reply
Ron
You have a unit pump that is starting to get glitchy just run it till it starts getting trouble some,this can go on for months / years If it becomes to frequent then do somthing with it!
Yes its servicable but you need to have the Cal code installed at the dealer ,Also note! If I were you I would take the covers off the unit pumps and check all the bolts for tighness, I did one yesterday (Pump three ) the bolt on one side was about to break ,when I went to remove the pump the bolt broke off and the other was loose This May be the cause of or just a symptom of your problem.
You might check the underside of the heat shield and make sure that it isn't contacting the terminals on the EUP intermittantly.
