Yikes
fuzzychicken
2007 Mack vision came from the factory with duals but changed to super singles right away. at just shy of 400,000 mile had a left front drive axle outer bearing failure. bearing cage disintegrated causing tire, hub and axle to part way with the rest of the truck. axle had the required amount of oil. only the hub nuts kept the assembly on the truck until the driver got stopped. has anyone running singles had this problem ?
