Torque For Axle Nuts
slspacek
Does any one know if there is a reccomended torque value for reinstalling the nuts that hold the axle in the rear end? I have a 1966 C-95 fire engine that was towed recently and now it's time to reinstall the axle and gaskets. Should I just tighten them down with an impact wrench? Thanks fellas.
Sean
Sean
That's normally how it's done in our shop, but just in case you're a stickler for procedure here are the torque specs:
Single Axles [RS 23] 118–142 ft lbs
34,000–38,000 lb. Axles (Eight 9/16-inch Studs) 100–125 ft lbs
44,000–52,000 lb. Axles (Six 5/8-inch Studs with Conical Washers) 118–142 ft lbs
Drive Flange Retaining Nuts for Two-Piece Splined Shafts 140–171 ft lbs.
You are the man!
Wasn't sure if I could do any damage by over tightening, I am not a mechanic by trade.
Thanks again.
Sean
You are the man!
Thanks again.
Sean
You can use the impact wrench, just have to use a little common sense with it!
