Mack Dm Queestion
Anyone that has backed a DM into an asphalt paver will tell you the reason for the off set cab is for visibility,you would just not believe the difference between an off set cab and a regular cab unless you drove one yourself.
Amen :thumb:
later yall
:mack1: aka bulldog man
I seen where a U tractor was used for local dilivery with box trailers and the driver said it made it a lot faster to back in to docks because he could see the end of the trailer. Which that would go along with the better visibility Mack claimed. I remember seeing Transcon using U models for over the road use as well. That was around 1979, or 1980. One thing for sure, Mack would try different cab styles, and they seemed to work.
Have a good day,
Bert
APA had a single axle U-model at the philly terminal with a hydralic fifth wheel,i used to come in and spot trailers on saturdays sometimes,and let me tell you,i was a BLINDSIDIN' S.O.B! LMAO!.............Mark
