How To Disconnect Temp Gauge '42 Ls Type 80
Phyrphighter
Hello all,
I am attempting to remove the gauges from the dash of my 1942 LS type 80 pumper to have them refurbished. The only thing holding that up right now is I cannot figure out how to remove the copper line that goes from near the head of the engine to the back of the "temp" gauge. When I loosen the nut on the back of the gauge, the line does not to seem to come out and the entire gauge is loose within the mount. On the engine end there seems to be two things I can put a wrench on at the sender- when I loosen the smaller one, I still cannot seem to pull the copper line free of the engine. When I loosen the larger one, I end up with the entire sending unit out of the engine ( and antifreeze comming out).
Is there a way to remove this sending unit at the back of the gauge ?
Barry Lasky
Hello all,
Barry Lasky
They do not come apart. From the back of the gauge to the temperature sending bulb is one piece. If you break it, it is garbage.
