Spark Plag Gap
Have to change the plugs on 1957 707 thermodyne fire truck. I was told the spark plugs are champion J 6 C. Does any one no the correct gap setting?
Thanks Joe
Thirty five thousanths will get you in the ballpark.
A J6C is still a very common plug.
I posted this under the mack gas engine thread but ill ask you guys as well. Just ordered rotors, caps, wires and plugs. I gave the specs for the plugs right from the manual and the plugs were two different part numbers.. My trucking company that gets all of my stuff was kinda curious why.. I do remember the manual stating i believe the RS being #18 and the LS being #16.. Not sure what the two numbers reference but they came in under two different part numbers and the supplier actually listed specific placement instructions for the respective plugs???
Allison,
The plug placement in the heads is different on either side, so the plug lengths are different so they have the same reach. This is only true on the 707's with plugs on left and right sides, some 707's have them all down the same side, such as the 1960 707c. It takes 12 of the same type of plug for that engine.
Firemack
