Traction control valve/ABS, as to why it is leaking, well you can't tell that from a picture. 1st thing to do is disconnect the electrical and see if it still leaks, if it does it is the valve, if it doesn't then you have a traction control problem.
Edited by Geoff Weeks
https://www.bigmacktrucks.com/topic/76105-cxu613-air-leaks/#findComment-585157
