I was able to take the bolt down floor panel up enough to disconnect all the air fittings on the petal and remove it from truck.   Once out I took my time soaking it with PB and tapping it with a hammer lightly.  I was able to get 2 freed up that way and they work fine.    Check your brake cans.   If they have the emergency brake they will have a hole right in the center for a caging bolt.    On some of my B’s over the years they changed just the rear most axle on the tandem to spring cans.  The front rear end still have the original air chambers with no emergency brakes.
