3 hours ago, Straydog954 said:
Hello everyone. Can a Crd921 front rear be used in combination with a CRD93 rear rear? Also what is the difference between a CRD93 and CRD931 rear rear ?
Yes, CRD921 can be used in combination with CRD93. "1" in CRD921 & CRD931 stands for Inter-Wheel Power Divider/Limited slip differential between wheels. You will need different axle-shafts if you are mixing and matching.
https://www.bigmacktrucks.com/topic/75687-rears-q/#findComment-577744
  • Recently Browsing   1 member
