Question
Goodevening everybody, I'm hoping someone on here can shed some light on this situation. I've got a 1991 CH 613 e7 350. It does have the bosch pump but it is electronically controlled. Over the past year the electronic malfunction light would come on periodically and the engine would de rate the power. Completely gutless when the light came on. I could cut the switch off and back on and the light would go away and back to normal engine power. But it never had any codes stored while doing this. So we couldnt trace it down. Fast forward to a week ago.. the light came on and I done exactly what I have done the previous times, cut the truck off and back on. And its 100 percent full throttle. Almost like the rack is stuck wide open. But the key switch will shut it down. If you crank the truck back up, does the same thing. Wide open throttle. Does anyone have any insight to this? Or had this happen before? Could it be the Bosch FIC? Has that been the problem the entire time? Any help is appreciated. Thanks!
https://www.bigmacktrucks.com/topic/75683-ch613-overfueling-e7-350/
  • 0
Thanks everyone for the info. I ended up getting the truck straightened out. I bought the bosch FIC from trans source in Greensboro. Their unit had gone bad as well. I did however get a FIC and matching Vmac controller from a guy in Indiana....
However it's cool to hear you guys are in NC as well! Thank yall for the help!
Answer this question...
