1955 Mack LTL 5-speed clutch parts needed
Hi any ideas where to buy clutch parts (plates, release bearing, spigot bearing etc). If needed I may be able to have my clutch plates resurfaced with new friction material but need the associated bearings etc.  Trans has the following casting numbers on the side: CSTG     284 KBK 581 A  and Part 284 KB 583 A
thanks for the help!
cheers
Edited by harley-jm
  • harley-jm changed the title to 1955 Mack LTL 5-speed clutch parts needed
South Bend Clutch did my double disc pusher clutch years ago. They put heavier springs in it and ceramic friction material instead of organic as original. A huge difference all around and a really good job, no more slipping clutch even at peak power. I had my flywheel resurfaced locally.
Have them rebuild your pressure plate and disc with better materials than original 1955 stuff.
South Bend Clutch
709 W. Jefferson Blvd.
Mishawaka, IN 46545
574-256-5065
www.southbendclutch.com
