Mack MR 2002 E-tech (Garbage Truck ) Random Shut Down
Hi There,
I have a shut down issue even after replacing the oil pump, changing bearings  and servicing the unit. Unusually driver goes out on route and 7 hours into the shift a shut down issue occurs. we believe it to be electrical. any pointers or advise on this??
Edited by JBrown Cayman
If it is a shut down by lack of oil pressure or over heat low coolant it should have codes it would also give you a one minute warning before shutting down! You need to clarify more info better help!having said that it issued garbage truck rat chewed wiring is common on these! Yup could be a. Wiring issue
Edited by fjh
