2001 Cl No Dash Lights
It's a truck at work 2001 CL-713, the lights in the center of the dash work (valves and switches), but not the main gauge cluster. All gauges work properly otherwise. The fuses/CBs/bulbs are good. I'm just wondering if anyone has run into this before, or if it's time to start tracing the white wires?
-Adam
Edited by Squid
yes i have the same problem right now in my 93 CH, its the connector on the back of the whole gauge cluster panel where the wiring harness plugs in. i had fixed it to make it work cuz its rather expensive but it quit working again. hope this helps.
later on
1993 Mack CH613 350 V-mac complete with Blixxton II module, RTX14710B Fuller tranny, 4.17 ratio 38K camelback rears, converted to 5-axle dump truck in 1999. Over 1 Million miles and counting on original motor
