I've attached a video from yesterday, but its really bad since had my 4-ways on the whole hill so all you can really hear is BEEP BEEP BEEP... had about 45 cars behind me at the bottom of the hill ...
Anyways, whats going on is when i'm in the 1400-1700RPM range when using the engine brake the truck starts to bounce almost like its driving overtop of small bumps in the road. Im just wondering if the transmission may be going bad? Any tips on what you might think the problem is?
Thanks guys, your the best
Brandon
I doubt its the trans, sounded like you could hear the bounce in the exhaust, any chance that hill was slick and you were slipping a wheel causing some hop in your camelback suspension ?
yeah at the end its definitely audible .. the hill i was going down was completely dry as well.
Just for reference, this is the same truck that backfires out the exhaust when the engine first starts to warm up while using the engine brake
im not sure, i'll have to pull the piping off and inspect for shaft play. It looks to me like it's a relatively new turbo housing, so im guessing it was replaced at one time ... but looks can be deceiving. i'll let you know what i find
"Backfires out the exhaust while warming up using the engine brake", well it actually makes me think the valves need to be adjusted or it may be slightly out of time somehow. An engine brake works by opening the exhaust valves at the top of the compression stroke before combustion and the power stroke basically turning the engine into an air compressor. By the sound of a "backfire" it would seem to me that the combustion was taking place before the valve opened making it louder thru the exhaust. As for the hop it just seemed like Camelback hop to me does it do it on flat ground or just on steep grades?
