Injector oil leak
woodrome
I have a 2004 CH with a 460. Oil leak on right side of motor, looks like it is coming from around the injectors. Is it possible for oil to leak from there and what is involved in repairing this. If it is not coming from the injector, then where could it be coming from? Any help would be greatly appreciative.
Mine does that. Leaks around the injector tube. Recently replaced exhaust manifold studs and sealed them up good but still have a leak on #6. I'm wondering if the plug under the valve cover where you pull the injector is letting a little oil by? Just haven't checked it out yet. Trey
If it's fuel that's leaking you need a new fuel line. If it's oil and it's coming out from around the injector line it's probably a hard, dried out or cut o-ring on the top end of the injector.
