Six Rod Suspension
ama60526
Does any body know if the six rod suspension out of say a CLR will fit into a series II Superliner???
Thanks
When you say 6 rod I suspect you have the Renault hub reduction axles on the Renault 6 rod suspension. The frames are the same but I guarantee you will have to drill new holes in the Superliner to bolt it on.
-Thad
Not to sure what brand it is but You are most likely right in saying Renault. I only have 38's on pedestal So before I take them out to put 44's on eagle claw I thought I would see if the six rod might fit in without to much trouble.
Thanks
Thanks
Good luck in the transplant. I have seen some Superliners with the factory Renault hub reduction axles.
-Thad
  • 4 weeks later...
it does fit and by the way are you sure its not hedrickson 6 rod?it was a option is aus in clr's me personnally i would stay away from the renault/berliet diffs they are major trouble it cheaper and easier to get a chassi cutoff out off a star than too try and do what you want too.8 grand will get you diffs and all suspension components.
  • 3 weeks later...
Thanks spud. So are you saying it's worth while getting the rear end cut from a western star with six rod and putting that in rather than the mack rear end. I like the idea of the x locks as well. Can never have to much traction
