V8 Cummins Diesel
Hey, yesterday I went and looked at a V8 Cummins naturaly aspirated diesel engine and a Brown-Lipe transmission. What I was wondering was what is the model of the engine how good is it and how good is the transmission. The only thing i could make out on the engine tag was the raised numbers.
This is about the order of them from top to bottom:
1789 V8 170
9-70 1214-00
3300 F048788
The guy said the engine has 470 CID. and 170 HP. It is 28 IN. wide & 44 IN. long.
The transmission is a Brown-Lipe
Model: 6352
Low Gear: 39.07
Serial #: T900157
If any of you could help me out with this, I'd appreciate it, Thanks, Daniel
The small V-9 Cummins have a reputation for not being the most reliable engine in its class. The trans is a Spicer with a low-gear of maybe 9.00 to 1 it would not have a first gear of 39.00 to one.Even if you put a auxiliary trans. brehind it with a deep first gear the reduction would be approximately 18.00 to 1 which is a low first gear. Joe D.
