Ch600
Does anyone know if a 613 cab will interchange with a 600?
:SMOKIE-LFT: CH613 cab is the same as a CH600 cab. I think the difference between the two models is the frame 600 is a 1/4" single rail and 613 is two 1/4" rails. Cabs should be the same.
The cab itself should not be a problem. The real problem will be if your are taking a cab from one year and trying ot make it fit on a truck from another year. The plug in electronic crap makes one have to be extremely careful about making sure what you are buying will fit what you got. The only difference in a CH cab is between the set forward and set back axle configuration. The difference is to the lower cowl panels. Good Luck.
Interested in Old Trucks? Check out:
www.antiquetruckclubofamerica.org
