Could A B-421 Come With A Diesel Engine?
DMorgan
I believe the B model number (eg. B61, B42, B81 etc) will tell you if its diesel or gas. The first number tells you the chassis duty rating, the second number will indicate if its diesel or gas simply if the number is odd or even. An odd second number such as B61 or B73 indicates diesel. B42 or B60 indicates gasoline.
Check out this B model information page: http://oldmacksrus.com/Info.htm. Check out the B model standard engines link.
-Thad
