Hello all, I'm having a bit of trouble with an etech 460 and would appreciate any input you may have. The number 2 fire ring started leaking compression into the water jacket and number 3 looked to be close behind. Liner protrusion is in spec on all cylinders, but some are at the low end. I've read input from other members that said the 460 HP engines work better with the liners set at the top of the .023 to .029 range. I lost a head gasket under this head 200k miles ago, but on the rear 3 cylinders. I swapped heads front to back at that time and the now rear head looks fine, as it did then. My questions are, could the head be the problem, or are the cylinders just too low? Also, is my only option to raise them to cut the counter bores and shim them up? Did anyone ever produce taller liners for the higher horse engines?
https://www.bigmacktrucks.com/topic/76513-etech-cylinder-liner-question/
