Dozer From Pa To Sc
rebelend52
Boyce,
You are right - that D-4 is the perfect load behind a B Mack.
If memory serves me, that tractor with the blade might weigh
around 10,000#. If it does, why not look for someone else to fill
the trailer?
The dozer will go on a lowboy, a step deck or even a high flat,
as long as you can load it and unload it.
I'm just thinking out loud - but why don't you look for someone
who might want to move a truck or another tractor in your direction,
from Pa. or the general area.
Or maybe someone who wants to move something north from your area,
so you might get a one way rate.
You might even check with tractor and equipment dealers in your area.
Sometimes they are transporting to and from the auctions, and might be able to help.
Good Luck. And post your contact info here on this forum, so everybody is thinking
about it.
Paul Van Scott
