T2130 Trans Sticking In Reverse
Noid93
My 97 CH had a snap ring in two pieces in the transmission oil when i drained it last. Between the last two changes it started to engage both reverse and 1st if you took it out of reverse while it was not stopped or had some sort of torque on the trans(not stopped without the clutch brake engaged for example). Obviously its in the sliding gear i belive(the snap ring was about three inches in diamiter). If it is in both gears and rolls a little, it will not come out of first with the stick without being pulled/pushed a very short distance(two inches or equal to the amout it rolled). Any quick fixes, has this happend to anybody else, and anyone with a used or fresh reman t2130 or t2180?? Thanks for your time and help guys.. :mack1::SMOKIE-LFT:
Curt
Noid93
There Is No Replacement, For Displacement!!!!!
