Fault Codes On My 2005 Cv713
I am getting these 2 fault codes 5004-02 M136 and P084-05 M142. What does these codes mean?
The M136 fault code is ABS sensor 4 (right rear axle wheel speed sensor) erratic reading from sensor, the M142 fault code is road speed sensor (in the transmission output bearing cover) open circuit.
Thank you. Is M142 the reason why my odometer stop working? Since these codes came up my odometer reading has stopped.
