cfd511
Bulldog
Everything posted by cfd511
  1. Anyone know a nice Alcoa rim that would look good on a 2002 Mack rd 10 wheel dump truck and the back spacing needed . Thanks
  2. cfd511
    Dump Bed
    I'm still looking for a dump bed 15-16 ft . send my pictures of what you got 631-774-3610
  3. cfd511
    Dump bed
    Is this bed still available .
  4. Hey I just needed to take a section from it . i have the other section available if you need .
  5. Hi guys I’m still looking for a 15-16 ft dump body . Anyone have anything ??????
  6. I don’t use conveyor or any of that stuff anymore. Will get pictures in am
  7. I don't mind leaving a pump connected to the front but i just need it to be smaller . the pump thats one there nows is 12 inches or more long . its two pumps in one. the front pump runs the plow and dump bed. The back of the pump (closer to motor) use to run all the components in the dump body Ie the conveyer chain and spinner for salting. If i can find a pump half the size would be much nicer so i can get rid of a lot of the unused hydraulic lines. right now i have it connnected to keep the pump from burning up. Any ideas
  8. I have a 2001 Mack 688 with the 400 and 18 speed mack tranny. The truck was an old county plow but still in great shape . i painted the frame ect. My issue is I'm trying to make the truck nice but these trucks had the hydraulic pump running off the front of the truck which makes the number stick out. This pump is a two stage which i don't need anymore because it only is needed for the dump bed and once and awhile a plow. so my question is how do i get the pump running on a pro system which is connected to the tranny. anyone know part numbers and what i would exactly need. Any help would be greatly appreciated.
  9. cfd511
    Dump bed
    How much you asking . nice bed
  10. Awesome thank you
  11. thanks for the replys . Its def a learning curve. i started letting rpms drops 300-400 rpm and slowed my shifting down and not let the revs go so high and boom shifts a lot better. thanks again .
  12. I have a mack 688 2001 . I wanna add air lines so i can tow trailers . i just had the plate installed on the rear. anyone have any pictures or guidance of an install. im goo with running the air hose and connections just need some guidance.
  13. this is my first mack
  14. newer to use . I'm eastern long island in ny.
  15. cfd511
    Dump bed
    Look for a 15 or 16 ft dump bed that would fit on a Mack 688 .
  16. I have a 2001 Mack RD688 dump truck which was county owned at one point . I don’t know how it felt when it was new but it seems really difficulty to shift all the time. It’s always grinding . The tranny is the 18 speed maxi torque connected to the Mack 400 . Is this normal or should I get it looked at.
  17. local or a drive ? all the good one are hours away lol.
  18. Look for a 15 maybe 16 ft dump body used. anyone got anything laying around ?
  19. So my horn doesn't work and hasn't worked in some time on my dump truck and i have a few guys taking there road tests with the truck . When i push horn on steering wheel nothing. I found the horn mounted inside the hood passenger side with a wire broken . Great i thought easy fix, Nopeeeeeee. I test the wires and I'm not getting any power when i press the horn in the truck . I have no idea where to start looking . anyone have any ideas or diagrams. 2000 mack 688 dump truck. Thanks and merry Christmas
  20. cfd511
    Dump body
    Looking for a 14 ft dump body for a 2000 Mack 688 . Let me know what you got . 6317743610
  21. Looking for a 14 ft dump body for a 2000 Mack rd 688 . I currently have a tenfold which is rotted out pretty badly . Send some pic of what you got or text 6317743610
  22. Any idea where exactly . I can’t find it .
  23. Anyone know where the low air buzzer is on a 2000 mack rd. its not working and i can't seem to find it. one of my employees needs to take his road test in the truck and i gotta fix it. thanks again. also if you have a picture of what it looks like.
  24. i believe is was registered for 54000 because the guy really only plowed snow with it . ill post pic tonight and thanks for the info. .
  25. no lift axle just a tri
