T-Mack1
BMT Benefactor
Everything posted by T-Mack1
  1. Here are pictures I took of the B85 enclosed cab firetruck that is in storage at the Mack Historical Museum. Taken 12/23/2024. I was looking for reference pictures for how things are laid out for our restoration of an open cab '58 B85F hook & ladder tractor.
  2. I got chance to go to the Mack Historical Museum on December 23rd. I had some stuff to drop off (framed pictures that once hung in the old World Headquarters). I also wanted to talk to them about my brother Jack & my B85F. And to take pictures of the enclosed cab B85 firetruck that they have in storage for references. It's in original condition, but needs going over. Plus, my Mack Trucks employee badge is getting turned in Jan 10th when I retire, so I wouldn't be able to "badge" thru the front gate soon. (note: since Mack Defense has a small assembly line in the facility, the gate is now manned by a security guard). After looking at their B85, the curator Doug Maney asked if I submitted a request for info. I told him yes, back in the end of November. He said that we should be coming up soon. Then he asked if I wanted to see the build sheet...... My response was "Of Course". Yes, I held the build sheet in my hands. Our truck (B85F-1211) was third of three trucks on the order (see picture). The order sheet has engine, trans and axle serial numbers. And, if it's anything like how we run now, it's a "as planned" number. It looks like we have the axle from 1210. Not sure the number on engine is a serial number or a build date number. The number of characters in the serial number doesn't match the stamping. I haven't tried to contort myself to find the trans SN yet.
  3. Nice, hope we can get somewhere near that HP once we get our engine running. Here is what's stamped on our engine, lower right side of the block...
  4. Weak spark could be multiple things. Dirty points, Condenser on it's last legs and as you state, the coil going bad. Do the cheap stuff first....... - I would first do an Ohm reading on the coil. Sorry, I don't know the spec off the top of my head. Usually 2 to 4 ohms. - The condenser should be 0.25 uFD. I know that because I have a real condenser tester (old school) and just bought new ones from Brillman Company in Virginia. Also found out the rusty ones someone had in our cab were also reading good (including a old Delco-Remy one). - Points.... run 800 grit or higher sand paper across them. The black colored sand paper will show a white trace if there is corrosion build up. If you get a trace on the paper, do it again until you don't. And finally, something you can't see on a distributor with a cap is the sign that a condenser is on it's last legs. The points will be arcing when the engine is running. That arcing is what destroys the points. On things like lawnmowers, Old motorcycles, minibikes and some generators, this is a handing thing to know. Tom M.
  5. 25 ton bottle jack are still an available option on new Mack's. Not many people order them. They take up space and the service truck that comes usually has them.
  6. Signal-Stat still makes the column turn signal thing. Mack still using a similar one on the COE truck (MRU or now called TE) that are made today. It doesn't have the indicator light in it since that's in the dash panel.
  7. found it, see attached. Again, not sure it's the same, but the fuse panel looks basically the same. Mack-Fuse-Listing-2013.pdf
  8. From the factory the list is taped in a sleeve on the fuse panel cover (also called the pie plate). Some where I have a list from 2013. Not sure if it's the same as 2008, but it was same as 2011, when I started at Mack.
  9. That's called "Park Brake Lighting". It's still an option on brand new Mack trucks.
  10. Merkle Logistics' 1986 MH Ultra-Liner, hauling Tom & Jack Mack's 1957 B85F Hook&ladder tractor. Dec 7th, 2024
  11. Mike, are you related to Mark? I meet him at Trucktober Fest this year and have his card.
  12. TE = TetraPro, which was the MR or MRu.
  13. Trolling for a while.
  14. The Low Entry refuse model "LR". AKA Garbage Truck. Diesel (Mack Eng,) and CNG (Cummins Eng). Steering configurations: Left hand only, Dual position (R & L) and Right hand only. Note: it takes about 4 or 5 turns to get use to switching to the RH steer, You still use the Bulldog to line up in the lane only instead of the white line on the side of the road, you use the Yellow center line, but still un-nerving pulling in to a garage bay. Also, the model that was formerly called the MR of MRU. Now TE for TetraPro. Same basic design for 30 years. Diesel Mack Eng (both sizes) and CNG (Cummins Eng). It comes in the following Axle - Drive configurations: 4x2, 6x4, 8x4 (dual steer axles), 8x6 (Tri-drive), 10x2 (odd looking - dual steer axle, 1 drive axle and the rest drop axles), 10x4 (Tri Steer), 10x6 (Dual Steer, tri drive), 12x6 (Tri Steer, Tri Drive) and the 14x6 (long and doesn't turn on a dime)
  15. If it follows current scheme, and it looks like it does....... 1 = USA M= Mack trucks 2= Incomplete vehicle which means it was heading to a body builder. 1 = would be complete vehicle , basically a tractor. N2 = model 08C would be a engine, trans, axle combo. (really big list that actually has some logic to it.) 9 = parity bit. It's something used to double check that the number gets transmitted electronically correctly. C = year made A = plant (I would think that means Allentown) Macungie is "M" 003715 = Chassis number.
  16. According to the Mack Museum, Mack made trailers from 1927 through 1944. A guy at work has his father's old title for one. The trailer is long gone.
  17. Family photo's. The two guys in the photo are the son's of Jack Mack, the founder. My grandfather, Carroll Mack, is on the right, and uncle Kenny on the right. But, read the back of the photo. They were on a trip to visit one of the salesmen that sold trucks to Pancho Villa (the hero of the Mexican revolution).
  18. Full truck assembly at Macungie, Two assembly lines. One line for Conventional trucks, one for cab overs. We even assemble the frames again. They out sourced the tire mounting. Target is approx 120 trucks per day. That is if the vendors can deliver the components we ordered. Usually make around 100 to 110 a day.
  19. Hello All, An intro..... I'm Tom Mack, I'm the Mr. Fix-it type, who is rather mechanically inclined and also has a associate degree in computers. I'm weeks away from retirement, Yay!. I live in the Allentown, Pa area. I've worked in the electronics industry here for many years, until 2010 when I got downsized. Then, after being laid off for 7 months, I got hired at a local company..... Mack Trucks. I originally started on the production line. Now, for the last 7 years, I've been in the Quality Group at the Macungie plant (now called Lehigh Valley operations), in a cushy job. I'm a product auditor. Basically, I take a completed truck, look it over, test drive it and then submit a report to help improve the production line. This means getting to test drive a new Mack once or twice a day . Tough job but someone has to do it...LOL. My older brother Jack (( yes, Jack Mack)) and I bought a Mack truck. We both have always wanted one. It's a 1957 B85F, and is the tractor portion of a hook & ladder truck from Boston, which then went to East Hampton, Connecticut. and eventually landed in the hands of a collector in Connecticut. And was bought as a 15 truck package by a person here in PA. As you can see from the pictures, it's needs some TLC. The engine is free, the wiring is a mess, the body is really nice. We're not sure about the added on out-riggers. Not sure when they were added. Plan is get engine running. Get Brakes working to include converting to spring brakes (want it MAX safe since grand children will be riding in it). Then, I want a canopy top. Jack wants 4 doors, which is a long term project that we already brain-stormed. Tom Mack, The great-grandson of the Founder of Mack trucks.
