- 0
2007 Mack AC 350 turbo waste gate
Question
mimsriggers
Hi all! I have a 07 mack AC350. I'm getting a terrible screeching sound from somewhere around the turbo. After trying it while sitting I found it started at around 1200 or 1400 rpm. I then watched the waste gate and found that the noise did seem to be affected by the position of the wastegate linkage. I then put a small pry bar between the limit adjust screw or what appears to be such, and the noise disappeared. I'm wondering if 1. that's in fact what these screws are and 2. what it sounds like my problem could be. It seems like I could move the limit screw some and the noise would go away, however if that's the case am I making it so I wont get full boost? Perhaps the waste gate valve is bad? any help would be greatly appreciated. Thanks
https://www.bigmacktrucks.com/topic/76542-2007-mack-ac-350-turbo-waste-gate/Share on other sites
0 answers to this question
