First off let me introduce myself, I’m a full time diesel mechanic and starting my own mobile repair. I have a few good customers as of now. One of which is giving me some grief.
It’s a 2000 RD, I went out to it for a crank no start condition. Driver told me the truck just shutoff on him then wouldn’t restart. Go back a few days before it wouldn’t start. The owner went out to the yard the same day and no issues. Same as when I went out 2 days after. Started 6-7 times no problem. No obvious reasons as to why it wouldn’t.
Here’s what I checked.
cam and crank sensors. (Ohmed out good)
Plenty of fuel to the block and injector lines.
Fuel pressure 60 psi while cranking.
Tried known good ecm.
Checked power relays in cab as well as ecm fuses. All over 11 volts when cranking.
No loose battery cables, wires at starter relay or frame grounds.
Ground relay working properly, even jumped it with large gauge wire.
Tried unplugging cam sensor and leaving crank plugged in and visa versa.
I’m trying to get ahold of a laptop tomorrow to see if the ecm is seeing engine speed.
I am assuming ecm is powering up, electronic malfunction light comes on and goes out. No blink codes present.
Left sensor unplugged purposely to confirm ecm flagged it. It set a blink code.
It will run all day off ether but that’s not saying much.
If engine speed is seen I’m going after vecu next.
Sorry for the long post but I’ve read everything on here and on google at this point and trying to see if I missed anything.
https://www.bigmacktrucks.com/topic/75616-mack-etec-crank-no-start/
