I would like to begin by thanking you for reading this. I just got a hold of my first truck but it isn't roadworthy at the moment and I need to move it from Central Point Oregon to Ashland Oregon. (about 30-40 miles) I would be more than glad to cover the expenses of the move but unfortunately I can't do much more than that because with the holidays getting so close I'm a little short on cash. Thanks again for reading and have a good day.
https://www.bigmacktrucks.com/topic/5029-i-could-use-some-help/
For a 30 or 40 mile move you might consider talking with a local trucker.
Some ideas might include a local excavating contractor with a lowboy,
or a local flatbed carrier.
Depending on the truck, it might even be able to move on a tag type trailer
behind a dump truck, or potentially, a heavy pick-up truck.
I like to use the local trucks whenever possible.
You should try to get a fairly accurate weight, and measure the height, width
and length to give someone a good idea of what he is picking up.
Good Luck,
Paul Van Scott
https://www.bigmacktrucks.com/topic/5029-i-could-use-some-help/#findComment-24192
Good Luck,
Paul Van Scott
Thank you very much.
https://www.bigmacktrucks.com/topic/5029-i-could-use-some-help/#findComment-24209
