237 Jake
n2deep
This has probably already been covered somewhere but I can't find it so. The guys a watts mack called specs and they say my 237 needs a dynatard, some of the mechanics say a jake can be used. Whats the deal with this idea is it one or the other or will either one work. I have a couple parts trucks with jakes but no "dynaturds" as I am not thrilled about the thoughts of putting one on my truck. The only one I have ever driven worked as well as opening the cowl vent to slow down. thanks.
Interesting concept - opening the cowl vent to slow down!
Probably a reasonably cheap approach to auxiliary braking.
As I understand it, TEC Brake makes a kit that is designed for all
two valve Mack diesel 6 cylinder engines. I have one that is brand new,
and I checked the instructions that come with the kit. They don't really say.
Barry at Watt's Mack should be able to confirm the compatability with the
237 Maxidyne, but I believe that the TEC brake will work on that motor.
I was told when I purchased the brake that it was designed for the 673, 711,
and two valve Maxidyne engine series.
The TEC Brake kit is essentially a duplicate of the original Jacobs brake that
is now out of production. I understand that most, if not all, of the parts are
interchangeable, although I cannot confirm this to be true.
Best to talk to Barry. They have access to these brakes in limited quantity.
Paul Van Scott
The jacobs brake is fully compatible with the 237. They make 2 vlave and 4 vlave jakes for macks. The only thing different is the dia. of the valve stems. The install manual is downloadable from the TEC brake website.
Fred
15 gears...no waiting!
