Brake Issues On My H-63
Tony Ingram
:pat: Now that I've got the H-63 running, I thought now's a good time to take it around the block a few times. I thought I got all of the brakes dialed in pretty good but I was wrong. When I push the control valve in to release the brakes, I still have to get out and push the slack adjuster inward on the driver side rear can to move the truck. Once I get the truck rolling and begin to brake, halfway down on the pedal and it wants to stop immediately. When I take off the brakes feel like they're draggin a little too. Where do I start? I don't have any more leaks to speak of and the compressor's puttin out alot of air pressure. I replaced both valves in the rear also. Tried taking the covers off the rears to look at the brakes. Took both sets of 7/16" nuts off the top and bottom but noticed four 15/16" bolts need to come off to. Loosened them up and feels like they're spinning behind the brake cover. Do I have to take the rear wheels off to do this?
Sounds to me like its just an issue from the truck sitting unused.If your lucky,you can get all moving parts greased good,and just keep working them and eventually things will start working.Might also have a weak or broken spring in the brake chamber.
sounds like your s cam may be frooze up or the spring in the can is weak or broke or the big spring on your brake shoes is broke
Tony,
Just like the others have said - start by getting the drums off
and greasing up all of the moving parts.
That gives you a chance to check over the drums and linings too.
I would also take the activator chambers apart to look for broken springs.
The only issue here is that you could inadvertantly damage a bladder
in the can. They'll be old and perhaps dried out, and easy to damage.
They are easy to get and to replace though.
The spring in the chamber is to help return the brake to an "off" position,
if it's broken or damaged it will cause a dragging brake.
One other little item to check is the quick release air valve. Take a look at
the Bendix Air Brake booklet, available at Bendix' web site. It has a simple
diagram of a typical tractor/trailer air system, and identifies the QR valve's
location in the system. The valve could be plugged or damaged, and will cause
the brakes to delay on release.
Hey man - at least it runs!! What else did you expect?
Paul Van Scott
I'm glad it runs now. The thing has actually smoothed out really well. It doesn't take but a cuople seconds of the start button and it lights off now. I took the driver side dust cover off today in hopes I could see all of the brake parts. Couldn't see nothing though. The shoes still have atleast a 1/2" of pad left though. I'm going to pull the hub off this weekend while mama's out of town. I think I can get alot more accomplished without having to break away every few minutes to help her do something. I started the truck up and let it build air pressure after I removed the dust cover. I set the brakes and then released them. I looked at the driver side bottom shoe and noticed it was still lying against the drum. I pushed the slack adjuster forward and it lifted up and stayed put. I'm assuming the spring inside the hub is broke but who am I to say. I'll start there and work my way to the cans. If everything is good and I get to the can and find out something is broke would I be better off in the long run to just buy a new one? Also I have a crack in the side of my tranny case about four inches long. I talked to a friend who is going to tig weld it up for me next week. I had drained the fluids and inspected the inside as much as I could though the foll hole on the side. Can't see a whole lot though. No shavings or metal debris casme out when I drained it. Any ideas what might have caused it? It seems to go into all gears fine so I don't think something is broke inside. It's an aluminum housed tri-plex. ALso I'm looking for the rear exhaust manifold for this too. Paul, you might be able to help me out here. The rear manifold turns down at almost a 90 degree angle after passing the #6 cylinder. I think mine is off of a B model cause it turned down at a 45 between the #5 and #6 cylinder. I modified it to work but would like to go with an original. Need the MACK emblem and vetical trim strip to. Bought a new PP1 valve and showed my old valve (a Gustin Baker) to the old boy at the brake shop. Said he hadn't seen one since the sixties and had a buddy who rebuilds them. He sent it off to try and get it rebuilt cause he said it would be cool to put it back in the truck. I've got the new valve in already but who knows. If he can rebuild it I might put it back in later or just hold onto it. He's got an early 50's bullnose KW he just finished so I finally found somebody in this farm town who's into old trucks like me. I knew somebody had to be out there. Will try to post a few pics of the tranny and exhaust if I can figure it out. Forgot to tell you it does have spring brakes.
Edited by 16390
Tony,
I'll have to take a look at the exhaust manifolds.
I never noticed the difference between the H and B models.
Have both apart and visible in the shop.
The decision to start with the simple brake parts is smart.
As for the brake chamber - I usually rebuild mine, unless I'm updating
the truck to new spring brake chambers. So many new parts say
"Made in China" on them that I try to use old stuff whenever possible!
Paul Van Scott
I keep trying to post pics of the exhaust but it keeps telling me the file is larger than available space. I've seen numerous pics posted on other forums so I don't know what I'm doing wrong. I have some pics of an H-67 exhaust manifold from a guy in Virginia. I'll try and scan it so I can post it and a pic of mine so you can see the difference. Wish me luck. It will be later tonight so all of you east coasters will probably be done for the evening by the time I get it on here.
