So i own a 1956 b85 mack and there is a 1961 mack b61. My truck the b85 has a mack 9 speed and the b61 has a 20 speed quadruplex.
both trucks have a I6 thermodyne. Dont know exact engine model waiting on answers from the mack museum
would the 20 speed fit in to my b85 or will i need a different bell housing for the 20 speed
https://www.bigmacktrucks.com/topic/76375-question-about-thermodyne-transmissions/
Flywheel housing sizes are standardized. If your flywheel housings are both the same size, the Quadruplex should bolt up where the 9 speed was. Here is a link to help explain the SAE sizes: Sae PDF | PDF | Technology & Engineering
Keep in mind that the Quadruplex is longer, and may not clear the crossmember at the back of the cab.
5 hours ago, Brocky said:
Be sure to check input shaft lengths and how it fits your bushing in the flywheel.. You may have to change the length of your drive  shaft?? Then check U-joint angles..
This∆∆∆∆∆
Could have a clutch brake on the quad box, could have 2" input and 9 spd could be smaller and shorter.
Back box will be longer for quad over duplex which changes driveshaft.
What reason are you wanting to change them?  Is the quad a double overdrive?
Thank you all
- Steve s thanks for the pdf and the answer very helpful
-Brocky thats a good point need to check that
-freightrain yes im sure i will need new shaft for the 20 speed. The reason for me wanting a 20 speed is i always wanted a 20 speed truck you know shifting for 10 minutes to go from 0mph to 20mph no other reason i just think they are super cool
I think that’s the way mine is. It’s got  four positions on the auxiliary, but you can’t really use the low low in a full  up shift it’s been so long since I drove it anywhere… I don’t remember if it’s a 15 or 20 speed lol .. bob
Thank you all for the much needed information im pretty sure you guys have figured out that im as uneducated as it get in turking im only 26 and still learning tons of new stuff about these trucks and everyone in BMT is super nice to me. I did not know that was the case with 20 speeds but even tho i know now im still itching to put a 20 speed in there since i always wanted to dirve one with 20 speed (there is no logical reson for me to want the 20 speed but here im still wanting it. Its a part of the dream)
How about the 10 speed i have in my truck has low  high and 5 gears (technically 9 since it says no 5th gear on low) do i use the all 9 of the gears on that. My truck is not in driving condition right now so couldn’t drive it. Also why does it say no 5th gear in low.
Thank you very much. I feel very lucky to have my truck engine seems to be in good shape just need to find a new water manifold. Found a 2023 list of part sellers trying to see if anyone on the list has one in decent shape
