Posted (edited)
I have a 2012 Mack pinnacle chu613 with the mp8 that is having a no crank issue. I parked the truck in our lot, came back a day later and had a no crank issue. Automatically assumed starter since I tried to jump it at the solenoid and had no response. After replacing it still had a no crank issue so I started diagnosing the system the next day I come back and the truck would only get power to the dash in the crank position found the pre ems relay burned out replaced it and got power to the dash at run position again but was resetting power every 5 seconds found fuse 7 for ignition start burned out so I replaced it as well and have constant power back to the dash however when I try to crank it blows the fuse again. Noticed my engine hours have dashes would a bad ECM cause my blown fuse issue or am I dealing with wiring that is causing both? I have power to pins 57 & 60 on my ecm but it is also not reading engine diagnostics on truck all others are reading.
Edited by GGTtexas
https://www.bigmacktrucks.com/topic/75643-possible-ecm-issue/
Also has several codes:
MID 140 PPID 278 FMI 9 code- communication failure
MID 140 PSID 200 FMI 9- communication failure
MID 130 SID 250 FMI 9- communication failure
MID 130 PSID 200 FMI 9- communication failure
Seems like either a VECU or ECM issue. Anyone seen this before or have advise?
https://www.bigmacktrucks.com/topic/75643-possible-ecm-issue/#findComment-577264
Canbus problems and digital stuff in general is not my strong suit. However, there are people with video's on the net that can help.
It would seam, and I can be wrong, that something is bring down the bus. I think the way to test is resistance across the high and low canbus lines. If it is off, then start un plugging (disconnecting) modules until the one that is causing the bus to go down is removed.
Again, I am very weak on this subject, but with multiple comm errors it seams to point this way. What you don't want to do is start replacing modules trying to hit the right one, that can get very pricey and takes longer than finding the one that is causing the buss errors.
https://www.bigmacktrucks.com/topic/75643-possible-ecm-issue/#findComment-577372
