What engine?
"EN" is for engine.
"D" is for diesel.
"L" is for the lightweight aluminum bell housing, I believe.
"T" is for turbocharged.
"C" is the particular revision.  This is, I think, the last version of this particular Thermodyne.
This is a 250HP, 700 ft-lb, turbocharged 672 cu. in. Thermodyne.
A very good engine.
On 9/7/2022 at 2:18 PM, 1wonton said:
Thanks Double, appreciate the input.
ron
The "C" was pretty common in later R, DM, U, and F models.  Don't think they were ever original in a B model.
Here is a .PDF of some info on that engine.  The graph has the traditional signature of Mack engineer Win Pelizzoni on it.
endt673c.pdf
Edited by doubleclutchinweasel
46 minutes ago, steve s. said:
DC Weasel, I have a 1966 B61 that was built with a 673C engine. It has a rotary injection pump and a pressed steel intake manifold. There are many differences in this late production B model compared to earlier B's I have noticed.
Cool.  I knew the "C" came out right around the end of the B's run.  Was not sure if any made it into the B.  I think the earliest one I personally saw was in a '66 or '67 R.  May have been some in the earlier U models, but I don't know.
That configuration on yours is different that I ever saw.  Can't be too many like yours.  A rare jewel to be sure.  I don't think they made all that many B's in '66 (last year).  Thanks for the info!
