12spd and 4.17 rear.
Bliue dm
Most of the changes  in gearing here we used to do was to change to  4.64 due to the V8 ! Anything over 400 would eat the 4:17/ 4:42 ratios for breakfast in the offroad type settings  here!  lots of hills! Used rebuild lots of these top gear sets would pit out and break! the above ratios were a simple top gear set change!
5 hours ago, mrsmackpaul said:
I just calculated what I do, you dont wanna see my results
Give you speedy buggers nightmares lol
Paul
You could just about pull Christ off the Cross with That Paul...
Because those that matter...
don't mind...
And those that mind....
don't matter." -
  • 1 month later...
55 minutes ago, Steve L said:
I used to pull around 100 tons (don’t know what that is lbs) with a 237 F model 6 speed with 4.17s and never had a problem. So I’m sure it would do it easy Bliue
Short ton 200,000 lbs......long ton 224,000 lbs ...
Ed
On 4/11/2021 at 11:40 PM, mrsmackpaul said:
Or the ass out of the ocean lol
Well thats why these old trucks are rated to 115 ton (215000 pounds) from new
Originally had 5.73's someone pointed out to me a while that they had been changed as they are stamped 5.29
Paul
I never heard about Mack 5.29 diffs. They were 5.32 or 5.13. If a real interest I'd jack up a tyre and count the prop shaft revs after spinning the wheel 10 or 20 turns. Another way is removing that big side cover off a carrier and make the teeth count. Sharp method but the issue you only can see the top gear set. No access to the bull gear excepting removing the carrier off the banjo.
Vlad you are possibly correct
They were 5.73 when new, the carrier has 5.29 stamped on the top of it so I have just assumed that is what they are
I did have that big cover off only months ago as it was weeping around it and replaced the O ring, or maybe gasket goo, dunno now
Anyway that is my understanding, 95 km/h is revving pretty hard
That is on the GPS thingy mahbob
Paul
Paul
Paul, if you ever have one of those big covers off again it would be a good activity to take a piece of pencil and paper and write the number of teeth each of the gears of the top set has. You can't count the lower set teeth as I pointed but having the top set figures you can "count out" the ratio knowing existing combo's. Just let me know if you have any interest in the figuring.
