  • 0
2007 CXN ROUGH IDLE WHEN AIR COMPRESSOR IS PUMPING
Question
2007 Mack CXN has a rough/loping idle. Has to be operating temperature or warmed up a little. Noticed when air compressor is pumping it goes away. As soon as air dryer spits off, it goes to loping. No codes. Checked and even replaced cam and speed sensors. No power complaints. Supply pump? Doesn't make any sense.
Link to post
20 answers to this question
  • 0
i wrote to you about this post... well, here you are.. I figured its an MP. then could there be a relationship because of the drive gears. air comp. runs the tandem pump....
Link to post
  • 0
yes sir... well on this one, because I have lost a lot of knowledge on MP's since its been over 2 years since I diagnosed one, I feel it's best if I just watch.... You and "F" and a couple others will be a good source of help..  JOJO✌️
Link to post
  • 0
I actually had this issue with Volvo and Mack with 13L engines. Turned out to be the double idler gear. When the compressor was in operation the timing gears loaded up and the engine would run smoother after the drier purged then it would run rough. Usually you would hear some strange noises from the rear of the engine.
V
Link to post
  • 0
What engine is fitted in the vehicle?
V
Link to post
  • 0
Well, I'll sing the same song I always sing....   Have you checked fuel pressure?  it should be at 100 PSI, but 80 will be ok too..
Edited by Joey Mack
Poor spelling
Link to post
  • 0
So I've been sitting here for a while thinking about how the air compressor affects the idle smoothness.... I'm stumped... do you hear any noise behind the timing cover? like whining gears or chatter for example...
Link to post
  • 0
Don't know how it would effect idle, but the compressor is pulling air out of the intake manifold and has a short hose on each end of the metal pipe that routes behind the engine.  One of those could be split and your losing intake pressure until the compressor kicks on and is sucking more air thru the system?
Link to post
  • 0
Interesting perspective....  the only thing I can think of, is that the compressor is failing and has a vibration that may simulate a rough idle... I dont know...  I hope to learn something when the answer is posted.. jojo
Edited by Joey Mack
More content needed
Link to post
  • 0
The only thing that I can think of is, when the air compressor is on it puts a load on the engine and it changes the fuel map just enough to keep the idle more stable.
V
Link to post
  • 0
Okay I had 80 plus pounds on fuel pressure gauge and  even changed supply pump out. No change. Pulled nozzles out and had checked. I had previously(month ago) put a 736GB421M2X in it. When injector shop checked, other five were not popping correctly because surfaces being blown out between plate and the tip. The one new one was not a M2X, but a MX. Apparently packaged wrong from factory. After all this truck still has same symptoms, rough idle, etc. Could the air compressor drive gear be loose. Wouldn't it give me times of not pumping at all?
Still puzzled....Besides erratic idle, runs great down the road!
Link to post
  • 0
Looks like my links were bad , but in the link, enter SB261016 or SB261014 in the “Keyword Search” to locate the bulletins, then click on the SBXXXX to view
Link to post
  • 0
OK I have checked everything in SB. I eliminated everything except for air compressor. If air compressor is pumping motor is smooth. I replaced air compressor and still the same. I'm about to pull my hair out. Doesn't make sense. Tach gauge goes from 740 to 760 when it does it. i do not like throwing parts at a problem but I am baffled by this
HELP!!!
Link to post
Answer this question...
    No registered users viewing this page.
