2007 CXP613 CRANKS, No start
MP8......No engine communication. Checked power wires to engine ecm and have 12 volts to both. Checked fuses in top of dash and by clutch pedal. Other ecu's seem to be communicating. I have read where the fuse boxes go bad. Which one's are they talking about? And what are the sympton's?
Not much help but the only time I had a won’t communicate with Ecu I checked harness and grounds pulled a load through the harness with a head light both pos and ground had nothing coming out of ecu     It was a bad   ecu.  That’s all I have for you
 Share
