8.25 or 9 inch rim
Moparmike
Quick crazy question guys will a 11/22.5 tire fit and run fine on a 9 inch rim that my 315 tire was on..
Looked at changing hub drum to 10 bolt
3600 then have to buy tires and rims not a option
Called about new 8 lug rims 2600 then tires dont really want to spend that much either smh
Any advice would be appreciated thanks
15 hours ago, 6368 said:
yes..., but why?  usually 315 is there for the weight rating  ...11Rs don't even come close.  Also used 9 inch rims are worth more than used 8.25...perhaps you could make a deal with somebody.
Cost double the price  of 11/22.5 and here in nc dot says tire cant touch when loaded they just do touch I've had no problem with them but problems with dot..
Ocassionally I found out that the most of Japanise heavy trucks use those 8 lug wheels. Here are many companies which import used wheels from Japan and for trucks either. I saw pairs of quite good 8.25x22.5 Alcoas for reasonable but had no need in them.
