2006 CH Shake/Rough Idle
bgblk1968
 Share
No codes. Changed cam sensor, checked valve adjustment, fuel pump, return valve, unit pump rollers. Had one cylinder a little weak so replaced one pump and injector. Truck runs and pulls good, just shakes truck at an idle. It's not a big shake and some people don't notice, but you can tell something just is not right. Seems to be worse cold.
Merry Christmas everyone!
3 hours ago, MACKS said:
My 96 CL does the same thing,gotta set the idle rpm just right and then it smooths out nice..
Your PLN (tuned-up) is a smooth as silk compared to the E-Techs. They are a choppy devil till they are under load. Start’em up on a cold morning your neighbor will think you bought a steel kettle drum.
Edited by Mack Technician
Another reason to stay old school..lol
  • Thanks 1
 Share
