tie rod end and steering tube part numbers?
hello everyone, i'm looking for the part number from the tie rod end and the tie rod steering tube. the truck is a 1962 b 67 fa505 front axle. i stripped the steering tube down to virgin metal today and i cannot find any number? any help would be appreciated. thank you. tomvb.
There isn't a part-number for those tie rod ends because they were never available as assemblies. They are serviceable (rebuildable) tie rod ends (common back in the day). There used to be a Mack part number for a kit, as well as individual components.
Do you have the Mack line sheet for the truck?
Great. On the build sheet, what is the 1QHA number, including the P or AP (BP) number over to the right?
On a side note, those "AC" part numbers date back to the Mack AC "Bulldog". Even in the 1980s, Mack still had a few "AC" numbers in our parts system. (When a Mack dealer views the 1QH front axle arrangement to research the parts, newer numbers will be shown).
If you want, scan and attach that build sheet page.
Superb.
Did you inspect the ball studs? What's the condition of the springs?
If visibly good, try cleaning, re-grease, and tighten out the slop (don't over tighten).
The rubber boots you'll need are 95RU32.
If you call Watt's Mack (1-888-304-6225) and provide your front axle arrangment (1QH321AP3), they can research the part numbers on the arrangement, supercede and check stock both in-house and at the PDCs (parts distribution centers).
  • 1 month later...
I changed the one on my old R over to a commercially-available replacement tie rod and current ends.  Found an equivalent diameter rod of similar length.  Also, the old (bent) one was the "both RH threads of 2 different pitches" affair.  The new one I put in was one LH and one RH, making it a bit easier to find parts.
