MH single round head light grille section
MHfred
I have a lower right (?) hand grille section for an MH. This is for a single round headlight. I would like $25 for it plus shipping. I would like it to go to someone who needs it rather someone who wants it for a spare. The part number is superseded by "RH" so therefore I believe it to be for the right side.
The part number is "50908    RH".
The headlamp panels all had 6MF prefix numbers on the back. Yours might be 6MF532M.
For a standard MH with bright finish grille trim (not plain finish for UPS), the 6 sections are:
6MF530M - upper right
6MF531M - upper left
6MF532M - lower right
6MF533M - lower left
6MF534m - center upper
6MF535M - center lower
The Mack part numbering system, simply the world's best.
You might want to mention the "6MF" part number cast on the inner side.
I did not know what you meant by "6MF". I thought that might be a diagram number. Here is a picture and there is no 6MF series number.
Thanks for your input.
Fred, that's the right-hand headlamp panel insert, part no. 111MO51M.
(Left-hand is 111MO52M).
Note the Sheller-Globe "SG" logo.
6MF is the part number prefix for Mack grilles.
For example, 6MF59301P2 (Mack Western Cruise-Liner grilledensor) and 6MF519P2 (F models and R700).
