boost leak through air dryer?
1993 E7 350 full mechanical.....anyone ever hear of this?  not a constant leak but when pulling a hill, boost will drop in half, engine will loose all power, and a massive air leak can be heard right behind the cab, where the air dryer is.  after downshifting, boost comes back, no air leaking, then a few seconds later, same thing....might be happening when the dryer is calling the compressor to build air?  pretty sure it's an AD9 dryer...
Edited by dondiesel444
5 hours ago, dondiesel444 said:
it looks original!  so is it possible that's where the leak is coming from?  somehow the boost pressure is feeding back through the compressor supply line or something?
What is happening is the cut off valve is not cutting off in the drier.I had one same way and I could hear it but dont think it was losing that much boost.
