collision72
85 magnum e9 v8
I just brought a 85 mack magnum superliner., The head are off it, the previous owner told me head gaskets were bad,one cylinder is out of it also,which i dont understand why,the sleeves has alittilt rust from sitting,need some advise should i just hone and re ring them or buy new cylinder packs and does anyone know where the best place to get them.Thanks
Share this post
Link to post
You should sell it right back to me. That will solve all your problem. This is the one from Wisconsin?
Share this post
Link to post
Welcome to the board.
See, EVERYONE is just willing to jump in and take care of ANY problems you might have. LOL!!!
Have fun with it.
Share this post
Link to post
best of luck with it,,,and welcome...bob
Share this post
Link to post
I would try to figure out how deep the rust spots are and could be removed by hone keeping the piston/liner clearance limit.
If the rust isn't hard you may just get it off with sandpaper.
Currently I have Mack E6 engine wich was factory rebuilt with no miles but stayed outside for years.
The crank is new excepting one main but all the liners need replace.
Good luck with the project and welcome!
From posted above you can see your truck worth to be babied.
Vlad
Share this post
Link to post
If you have the money, do an in-frame. Someone might have had a problem with the motor and started looking for the problem. Have the heads done, new pistons, rings, liners, and bearings. Than you'll know what you have.
Good luck and welcome to the jungle.
Share this post
Link to post
