Air Dryer
Lillian
Help! I run a 1999 Mack CH13. Could you please tell me what is the recommended servicing of the airdryer for a regular checkup..someone told me once a year, and yet another said every 3 months or 24,000 km. What are the recommendations from the makers of the air dryers? I am having issues and need an answer. Thanks for your time!
I usually recommend replacing the cartridge at least once per year...just before winter. The manufactures will recommend replacing it more often, of course! What type of problem are you having?
In all the fleets,Ihave worked for,we changed the cartridge,and spitter valve once a year,usually 1-2 months before winters onset. The cartridge also got changed earlier if constantly cycled,or left alot of water on ground when cycles a couple times
James Spurlock
Palmyra,Pa
