Adjusting a Spicer clutch
diggerpro
I recently bought a DM Mack triaxle and today I went to adjust the clutch and it is different than the others that I own. I used to use a special tool and you removed the lock tab and bolted the tool on and used it to move the collar on the pressure plate. This one appears to have a hex head piece that I think has a gear on the back of it to move an internal ring , It has a spring behind it and you press it down to turn the adjuster. I moved it both directions today ( a little) and was wondering what direction the hex piece should be turned to get more adjustment on the clutch-
5/8 wrench, turn clockwise. wiggle it a little to make sure the spring pushes it back out
Yup, I use a shallow 5/8" socket on a medium length ratchet, push in and turn it doesnt take much with that style to see a difference at the pedal. Oh and like hatcity said make sure the detent engages when your done!
A 24" prybar is my favorite for holding the clutch down while I adjust one fits right between the seat and pedal and you can slide the seat up to get it down farther if you need to.
Remember don't over do it, a little goes a long way and spec is 1.5-2" free play at the top of the pedal.
