Jerky Brakes
Truck#1
I don't get much braking with moderate pedal pressure but then all of a sudden they grab like a S.O.B. (almost puts me through the windshield). It's the same with or without trailer. What should I look at??? The brake valve assembly on the firewall? I'm just guessing since I don't know. Thanks for your help guys. Rob
Are any of the axles locking up? Could be treadle valve or a sticking relay valve to either drives or steer,the crack pressure is off,and you get a sudden burst when it does.,overtightened slacks can do this also to close to drum and when you push a tad harder it'll lck up. Also is this an ABS system or standard system or an old unit with the i beleive is the 1121 system.(never can remember the number,the early 70's antilock system).
James Spurlock
Palmyra,Pa
Amen.
Been there, Fixed that.
Test or guess did you get that, test or guess that me you are trying on parts and hpeing but nyou need to connect a 100 psi air gage to the application line going to the relay vavle on the rear and to the front axle and check the press from the foot vavle as you posh the foot vavle pedtal down and it should be smooth as the pressure goes up.if it is ok then check the pressure to the chambers from the relay vavle at each axle and it should be smooth as you raise the foot petdal pressure and if it has a bob tail vavle in the rear relay then you will be limited untill you release the triler brakes. the antiskid or abs system will not make this problem. Late model get the blame for too many thins and the system will not cause that problem but a abs modulaion vavle that is bad can be deffective which does the same thing as the relay for the older trucks. glenn
Excuse my ignorance. Is the foot valve behind the firewall ( on a CH) that has a half dozen or so air lines connected to it??? If that is it...what does a replacement cost and how hard is it to replace??? thanks. rob
Yes, It's on the engine side of the firewall on a CH, no it's not hard to replace, but just make damn sure you put all the air lines back on exactly as they were.
