New owner of a 1964 Mack C600
Milaca
I repaired the PTO two weeks ago (broken shift fork, it's made of stamped steel and I was able to weld it back together) and now the dump-box raises, I can now start the truck from within the cab (corroded starter cables at the starter motor and corroded terminals on the ignition switch were the culprit) and I now have the brake treadle valve assembly repaired. Unfortunately, the brakes are not yet working as they should as the brakes are not releasing. Ran out of time/daylight this weekend so that will be my next project. I began digging a wildlife pond and I intend to use this truck to haul the spoil from the lowland up to high ground. If I dont get it done soon, there is always next year. :)
Edited by Milaca
Cool! Are you going to restore the truck? She looks good there, all them little things add up ya know? Keep up the good work and pictures! My U model doesnt have brakes either, the truck wont build air, so we didnt think it would move but it did. I think the compressors dead in mine.
  • 8 years later...
My Father and I bought a C-600 (model C607) in 1976. In my research I found that there are 4 sub-models; C607, C609, C611, and a C615. What are the differences in the different models?
George
