Two Speed Rear-end Help
on the '76 international dump truck my family just got, there is a box off the side of the pumpkin. The damn truck will only do 35 in fifth gear floored. On the dash there is a factory sticker which explains how to use split shift, or a two speed rear-end. In the truck there is not a lever, or visible button to change the rear's ratio, so my question is what is the real purpose of the box?internationalpumpkin.jpg
"There should be a switch on the shifter that you pull up or down , up is in hi down is in low. The 2 speed motor on your pumpkin doesn't look like it is hooked up . I don't see any wire going to it. The purpose of a 2 speed rearend is to allow you to take half a gear. Instead of splitting the gear in the transmission you are doing it in the rearend.
greg
There is a few yellow wires that are hanging under the frame, my step dad said they were going to it I believe. If anyone wants to see them, or any other aspect of this truck to help me figure this crap out, feel free to ask! oh, and the shifter does not have a switch on it.
Just been puttering with a two speed (Mack) The vertical round thing is a D.C. motor that is hooked to a 'screw' that runs the low and high part of the diff.
Should be two posts on the 'can' that the wires attach to.
Just bought a rebuild kit for mine @ $48.00 for all the goodies.
Packer
Keep a clutchin'
