obd2tool
Sign in to follow this
  • entries
    3
  • comments
    0
  • views
    1,184
Autel IM508 & APB112 All Keys Lost Programming for Toyota Camry 2016
Divad968
This post show you guide on how to use Autel MaxiIM IM508 and Autel AP112 to do all keys lost programming for Toyota Camry 2016.
Autel-IM508-&-APB112-All-Keys-Lost-Programming-for-Toyota-Camry-2016-1
Procedures:
Connect Autel Scanner IM508 to Toyota Camry OBD port,and connect Autel APB 112 to IM508
Autel-IM508-&-APB112-All-Keys-Lost-Programming-for-Toyota-Camry-2016-2
Enter “IMMO” menu–>Toyota–>Manual Selection–>Other
Autel-IM508-&-APB112-All-Keys-Lost-Programming-for-Toyota-Camry-2016-3
Then select “Camry”–>Smart key–>Keyless System(CAN)
Autel-IM508-&-APB112-All-Keys-Lost-Programming-for-Toyota-Camry-2016-4
Now select “Back UP Immobilizer Data”
This function is use to back up the EEPROM data of the smart box of the vehicle.The data can be used to generate the simulator key for emergency start of the vehicle to perform the key matching function.
Click “OK” to continue
Autel-IM508-&-APB112-All-Keys-Lost-Programming-for-Toyota-Camry-2016-5
Reading immobilizer data (make sure im508 connect to network)
Autel-IM508-&-APB112-All-Keys-Lost-Programming-for-Toyota-Camry-2016-6
After then save the EEPROM backup data file
Autel-IM508-&-APB112-All-Keys-Lost-Programming-for-Toyota-Camry-2016-7
Now press “OK” button to back,and select “Generate Simulator Key”
Autel-IM508-&-APB112-All-Keys-Lost-Programming-for-Toyota-Camry-2016-8
Select the EEPROM data.
Autel-IM508-&-APB112-All-Keys-Lost-Programming-for-Toyota-Camry-2016-9
Choose the backup file you saved just now
Autel-IM508-&-APB112-All-Keys-Lost-Programming-for-Toyota-Camry-2016-10
Retrieving critical data…
Autel-IM508-&-APB112-All-Keys-Lost-Programming-for-Toyota-Camry-2016-11
Key Type:SLK3
Autel-IM508-&-APB112-All-Keys-Lost-Programming-for-Toyota-Camry-2016-12
It will prompt you to connect APB112 key simulator,press “OK” to continue
Autel-IM508-&-APB112-All-Keys-Lost-Programming-for-Toyota-Camry-2016-13
Burning firmware please wait…
Autel-IM508-&-APB112-All-Keys-Lost-Programming-for-Toyota-Camry-2016-14
Now Autel IM508 programmer show you simulator key is generated successfully
Autel-IM508-&-APB112-All-Keys-Lost-Programming-for-Toyota-Camry-2016-15)
Back to menu to select “Add Smart Key”
Press “Yes” to use simulator key
Note:Each step must be completed within the specified time
Autel-IM508-&-APB112-All-Keys-Lost-Programming-for-Toyota-Camry-2016-16
The positions for learning include:5
Click “OK”
Autel-IM508-&-APB112-All-Keys-Lost-Programming-for-Toyota-Camry-2016-17
Put the simulator key APB112 close to the START button
Autel-IM508-&-APB112-All-Keys-Lost-Programming-for-Toyota-Camry-2016-18Autel-IM508-&-APB112-All-Keys-Lost-Programming-for-Toyota-Camry-2016-19
Then you will sound a beep,remove simulator key
Put the new smart key to learned close to the start button
Autel-IM508-&-APB112-All-Keys-Lost-Programming-for-Toyota-Camry-2016-20 Autel-IM508-&-APB112-All-Keys-Lost-Programming-for-Toyota-Camry-2016-21
After get two warming sound “Beep Beep”,remove new smart key from START button
Registering,please wait…
Autel-IM508-&-APB112-All-Keys-Lost-Programming-for-Toyota-Camry-2016-22
Learning succeed.
Autel-IM508-&-APB112-All-Keys-Lost-Programming-for-Toyota-Camry-2016-23
Now you can test the new smart key on vehicle.
Autel-IM508-&-APB112-All-Keys-Lost-Programming-for-Toyota-Camry-2016-24
Done
0 Comments
